Recommened tire pressure for Mud Grapplers
If I read the Nitto tire chart correctly, that is a LR E with a max pressure of 65. Also those tires are only rated to 2600lbs, unlike most LR E s which are rated over 3000lbs. I would run those at 50 since they are not rated that high.
I would not try anything lower that 45, and 45 only when unloaded.
I'd run 45psi and see how they wear and also rotate them every 4 to 5k miles. You may even get 25k miles out of them. They are not a long wearing tire.
