Vibrating BFG AT/KO on stock rims
I have a set of BFGoodrich 305s AT/KO mounted on 2004 SCab's stock wheels (18 inch). I get a slight shake (vibration) at 55-60 MPH. Is this because the BFG's are not supposed to be mounted on the F-150 stock wheels? I was told the tires are not to be mounted in a wheel size less than 8.5 inches wide. The stock wheels are 7.5 inches wide. Is this normal? Are the tires out of round? Should I have them re-mounted? Any advise would be helpful. Thanks.
You may have a bit of treadcap crowning going on as well because you are pinching that tire on a rim 1" more narrow than is should be. That causes heat at the shoulder area, and that may cause the interior construction to shift, throwing the tire out of balance.
Just because you can does not mean you should....
