Need to replace Calipar?
Old 09-28-2009 | 07:21 PM
I changed my pads and painted my calipars tonight and I found one of the master cyls on the front drivers side is cracked. This explains the excessive brake dust I always get with the LF, and the burnt brake smell i discovered last spring.
Is all I have to do is replace the calipar? I cannot compress it with the clamp. I read that if you replace one you should replace the other, but I am not that rich at the moment and I'm quite pissed off this one is cracked. I want to only have to replace it with a good one from a used truck in a salvage yard or such.
I'm putting the Motorcraft pads back on the drivers side until I figure out if this is all that needs done. I need my truck for communication. Any advice given please help asap, thanks.
Old 09-29-2009 | 04:59 AM
batn68's Avatar
if the bore is still good, rock auto shows a caliper piston u can buy for under 8 bucks not sure if it comes with the rubber bits but they have the repair kit for about the same price as well. Maybe a local auto parts store has them which if needed now would be more convenient but rock auto ships out rather quickly.
Old 09-29-2009 | 03:03 PM
Thanks, so this is replaceable? I know only a little about brakes and need to get this fixed.
Old 09-29-2009 | 06:12 PM
No one knows anything about these?.......
Old 09-29-2009 | 09:52 PM
HCBPH's Avatar
Calipers
Darren
If you aren't set to check for roundness and possibly hone the sleeves in that caliper, let alone pull a probable stuck piston out of it; I think it would be better to get a rebuilt caliper. Second option would be to get a comparable one from a recent wreck, not as good as a rebuilt but better than a questionable one. I've never done one, but I've watched it done and I don't feel comfortable doing it myself.
My 2 cents
Paul
