Tire Decision
Tire Decision
Alright its time for new tires- but which ones?
I have the FX4 with 20in rims stock of course stock size is 275/55/20
I was thinking of going with 305/50/20 will these tires fit with my setup?
If i wanted to add height to my truck what is a good size for stock 20's?
I have my eye on these tires? anyone have these?
http://www.tirerack.com/tires/tires....omCompare1=yes
Any help is always appreciated
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
The Cooper Zeon LTZ is an A/T tire. You might want to look a Toyo Open Country and Nitto Terra Grapplers but if price is an issue then the Cooper is hard to beat. Once you start getting into the 33" and above size the price does climb a bit. The 275/60/20 is a 33" that can be had at a good price. Check out this link. https://www.f150online.com/forums/20...-zeon-ltz.html
275/60/20 is 33"
305/50/20 is only 32"
Both should fit no problem, the 275 will fill the wheel well better and probably ride nicer (unless you are racing).
Nevermind...the 305/55 is 33.2" the only real difference is the profile.
