Squeaky noise after bearing replacement
did you pack the new bearings well with grease?
did you over tighten the hub nut?
brakes will have a slight "drag" at slow speeds, to be sure this isnt what you are hearing, take the front pads off and spin the wheel/ hub assembly by hand and feel if there is anything hanging up in the bearings
I reused them and i did grease the back side of the pads with waterproof bel ray grease. The sound is not occurring when i start to brake , it just starts at the very beginning at take off at very slow revolution then dissappear. I have a feeling i left the hub nut too loose, Be cause when i backed off after tightennig the hub nut, i was able to tighten it by hand and left it there.
regards.
regards.
