Will these fit?
Alright, well I measured the height of my truck, and the front end sits only 3/4" (33.25" front, 34" rear) lower than the back. Is that enough that I couldn't fit some 295's (33.4")? I found a great deal on some and hope they would be fine. If I did put a leveling kit on it, it would sit 3/4" high in the front, not something I'd like.
Wandell is right. I know, because I have ran 295's.. actually I am running them now. I made the mistake of trying to without lifting it and those things were rubbing into my wheel wells when I made any kind of sharp turn. I would not recommend trying to run 295's unless you have aftermarket wheels and some sort of lift. A coil spacer is not going to cut it.. well it may, but its going to be a close call. I ran 285's on OEM wheels with a stock suspension for maybe a year and a half with no problems. Then again the 285's are 32.8's as opposed to 295's which is a 33.4. The 285's are narrower also.
