Steering wheel shake
#31
#32
All you with this problem, it more than likely is unbalanced tires, often but not always occuring around 60-70 mph. If you can feel it in the seat, it's in the rear, steering wheel= fronts. Try swapping tires fron to back to see if it changes. Otherwise I'd say ball joint(s) or tie rods.
#34
I ordered a FabTech stabilizer kit for my truck, it would not fit. Not sure if it was because of the Superlift kit or not. I have had this happen also. My Ebrake cable was froze and slightly on, I do not use the Ebrake but have bumped it climbing in my truck. The whole truck would shake terrible. I will be putting in a 9.75 rear end with rear disc brakes and checking every suspension part this spring. Will see what happens.
