08 Harley Davidson Question
Hi guys, hopefully someone can help me out!
Backstory: I have a 2008 F150 Harley Davidson 4x4. I need new tires, and just ordered a set of the Toyo Open Country MT in 33x12.50R22.
Question: Will they fit OK with the truck at stock ride height? The stock Pirelli tires are 275/45R22, so basically 32x11R22. I know the wheels are 22x9" with 30mm offset (6.2" backspacing).
Really? With no leveling kit? That is great! I was hoping I could avoid lifting if it I could.
I was worried becasue people kept saying that a 2" kit was required for 33x12.50. When I looked in the wheel well there seemed to be plenty of room.
my 325/50/22 (35") A/T rubbed slightly on the control arm when i had them on a +30 offset and the tires are 12.80" wide
the 33x12.50x33 M/T are 12.40 wide, but have the large lugs.. I'm thinking they may rub slightly when turning the wheel at full lock, like U-turns..
But it will look really good on those wheels if you can deal with a possibility of minor rubbing when doing U-turns!
A/T's should work for sure if you decide not to run the M/T's
