Slotted rotorsssss
Slotted rotorsssss
finally placed my order on my slotted power slot rotors.
Breakdown:
Powerslot slotted rotors all the way around
Hawk HPS street brake pads up front
Ate premium one pads on the rear
should have everything by wednesday or thursday of next week. and will do the install next weekend. Painting my calipers black also. will post pics/and do a write up of the install.
Breakdown:
Totally curious?
I went with Power Slot Power Alloy Cryo-Treated Rotors.
yes the method did work. But it wasn't as easy it showed on the video. It took me a few moves of the rotor to finally get it loose enough to be able to hammer the rest of the way off. If you search You Tube for Ford rotor you'll find another video that shows the same method and it didn't work for him either. I was cringing as he was beating the rotor with a 3lb sledge and smacking the wheel studs. I alway put my lug nuts back on just in case I miss, like he did a few times.
I still haven't put it back together since I want to clean the out rim of the wheel up of all the rust before I do. I have some sanding flappers that should work good for that. I'll post photos on my other thread as I move along.
Wedge
Wedge
Nice, I did the same thing a couple months ago. Except I went with Hawks all the way around. Didn't really have any stuck rotor problems, but I also had my friend, who happens to be a 6'3, 285 pound ex-football player there to beat the crap out of the one rotor that did stick a bit.
If you haven't seen this http://www.youtube.com/watch?v=mtsTJCRljAs check it out. Interesting way to remove seized rotors without resorting to a sledge.
- NCSU
- NCSU
I was always told that vthe slotted are fine, its the cross drilled you have to be careful with. I have the powerslots and hawk pads all the way around & I feel much better when I have to brake suddenly now than before with the stockers
- NCSU
- NCSU
That worked for me but now as easy as it was in the video. I had to do it 3 or 4 time after rotating the hub.
Wedge
brake dust is very minimal, but i dont have black wheels that show the first spec of dust on them. The braking performance is a great improvement
