35" Nitto Trail Grapps w/ 18" Rockstars w/ 2.5" Level, 4x4 (Final Request)
Old 11-14-2009 | 02:16 PM
5.71" backspace / +18 offset, 6x135mm bolt pattern, and go with a 33" over 35.
Old 11-14-2009 | 10:46 PM
AAK625's Avatar
Why 33's and would that rim spec info apply to the 35's?
What rim width?
Old 11-14-2009 | 11:31 PM
33x12.5 with a 9" wide rim, thats what i personally believe looks best on any leveled truck. 35s are for the lifted guys.
Old 11-15-2009 | 12:35 AM
AAK625's Avatar
Was that a yes to my question then?
Old 11-15-2009 | 04:00 AM
If that answered your question, then it should be yes. I hate the look of 35s on a leveled truck regardless of rim size, looks too bulky and stuffed. You could pull off the 35s look with that bumper though.
Old 11-15-2009 | 04:06 AM
offroadn'98's Avatar
My opinion.......
Go with the 35's.....you kno the old sayin......"the bigger, the better!"
Especially with that bumper they'll look perfect!
.02...
Old 11-15-2009 | 09:31 AM
AAK625's Avatar
I am pretty set on the 35's due to the obnoxious gap in the front, but the jury is still out on the rim specs. Unfortunately, I think this will end in a snap decision and a lot of prayer to the Man upstairs.
Old 11-15-2009 | 06:39 PM
john151ama's Avatar
I have 07 with 2.5 front level. I went with 18 x 9 rims. I have 325/65/18 tires. Love the set up. Very minor cut of wheel well liner to pin it back 1 inch for turning clearance. Check out my pics, it will show you 35's and 2.5" lift works and is not a huge deal.I love the feel and look and I am happy with it. I drive logging roads but don't do extream off roading. I have +12 offset and 5.47 backspace.
Old 11-15-2009 | 07:14 PM
RANCHER150's Avatar
I have the
20x8.5 KMC Rockstars XD775
- 5.1" Backspacing (+10 Offset)
- 35x12.50 Toyo M/T
Becuase I have the Ranchhand Bumper Replacement on the front, no trimming was required there. On the back side of the wheel, where it look so close in the picture, I had to trim there, but no biggy. This trimming reduced rubbing to nothing, as far as everyday driving goes, but turning and hitting an incline or decline(mostly incline) at the same time is a different story. The rubbing at first made me cringe, but its still not bad enough to make me take my rims and tires off. Hope this helps!
Old 11-15-2009 | 11:51 PM
AAK625's Avatar
So, with all that we know now.... lol... Which specs do I want to go with? lol
Old 11-16-2009 | 12:23 AM
RANCHER150's Avatar
ha, if I could give you a straight up answer I would, but I just pulled the trigger and ran with it
Old 11-16-2009 | 04:16 AM
arkguy29's Avatar
Old 11-16-2009 | 11:05 AM
F_ast's Avatar
Seriously dude, you keep asking the same thing over and over...
From the testimonials on here, the following:
on an 8.5" rim, around a +10mm offset
on a 9" rim, you want a + offset. Between +12mm and +18mm.
on a 10" rim look form something closer to 0mm offset.
You will be able to run up to a 12.5" rim 33" or 35" tire with so minimal trimming... a little more trimming will be required the larger tire you go and the farther it sticks out.
Old 11-16-2009 | 09:29 PM
AAK625's Avatar
And my backspacing?
Old 11-17-2009 | 02:08 AM
backspacing is w/e the offsets are, the offset matters more and they're basically the same thing. What F ast stated is correct and accurate suggestions to what you should look for.
I would go with a 9" rim because 12.5" wide tires will mount to it better with less weight balance issues.
