Slotted and Dimpled Rotors
Well I got my rotors in yesturday and they look amazing I can't wait to put them on ....... Can't post a pic of them I'm on my iPod but will post it up when I get home and another one when I put them on and after a couple of days ill take one more
Just wanted to ask if drilled and slotted rotors will help stop more than just slotted ??? If thats the case the way I see it is the face of the rotor are the same as drilled and slotted same surface just not all the way throught so IMO if the face is the same and slotted and drilled give you better stopping power than slotted and dimpled would be the same with better strucual properties
Not trying to attack at all man just wanted to see if what I was thinkin was right
Thanks in advance
-Chris
Thanks in advance
-Chris
Thanks in advance
-Chris
Thanks in advance
-Chris
Slotted rotors are for higher heat situations like towing or mountains, and drilled are for when you need to get rid of gases created between pads and rotors(racing). Both take away rotor surface and tend to eat up pads quicker for normal driving. Just overkill. What the above poster was saying is that dimples are for looks only to look sort of like drilled, but they aren't and do nothing but remove surface.
Great answer just what I was looking for ........ i was under the impression that having a surface that would sort of "grab" a hold of the pad would make it stop better .... guess i was wrong :o
Thanks for the reply Blue
Thanks! I'm hoping to get them on this weekend sat or Sunday I can't wait...... Did u get the ceramic pads with it and if so did u see a decrease in the amount of brake dust produced by the pads
K ill do a search see what I can find...... What color would look good red or black right idk if ill do it changing them now but maybe in the future I may want to think bout it
Hoping to do the job tonight with my father at my firehouse yayy heated sub station lol
I went through several rotors before I came across Baer's crossdrilled and slotted rotors. They are AWESOME!!! I pull 20,000lbs+ with my F-150 and they handle it with NO WARPAGE! I have had them for ~ 100,000 miles or so. They are about worn out though... They have almost no slots left. http://www.baer.com/products/oe/decelarotor.php
Regardless of which rotors you choose, (if you have a warping problem) just be sure to use cheapo pads and not the ceramics. They will wear out faster but save your rotors.
Wow they are an incredible difference like night and day very glad I put these on I feel way more able to stop In A short distance than I did before. I would say everyone should do this because it's such a big difference and will maybe avoid an accident or save your life get good brakes it's amazing!!!!
