Need help with rims off sets and spacing please
Old 11-24-2009 | 07:36 PM
gp1200r2000's Avatar
Guys Im looking at rims and I dont understand the off sets and all that ****,I dont like the rims to stick out past the fenders here is what Im looking at I have the tires thay are 275/60/20 Cooper Zeon LTZ
here are the wheel info any help would be great thanks Guys
Offset: +30mm
Backspacing: 6.22"
both rims are the same,and thay are 20x9 also need to know if thay will fit with out the leveling kit or will I need it thanks guys I need some quick answers
Craig
Old 11-24-2009 | 10:37 PM
wandell's Avatar
A 9 inch wide wheel with 6.22 inches of BS is gonna stick out about 3/4 inch farther than your OEM wheels.
Old 11-25-2009 | 10:34 AM
Azblu's Avatar
Is there a simple way to explain what calculations you did to come to that conclusion? I dont understand backspacing and offsets either......Thanks!
Old 11-25-2009 | 10:39 AM
wandell's Avatar
Just use the OEM wheels as a reference. The OEM wheels are 7.5 inches wide with 5.5 inches of BS.
Old 11-25-2009 | 11:17 AM
svt4lyfe's Avatar
right, but different 9" wide wheels with the same offset can have different backspacing though correct?
For instance, the XD hoss 20x9's i want are +30mm but have 5.71" BS?
Old 11-25-2009 | 11:07 PM
wandell's Avatar
No, if the wheel width and backspacing are the same, the offset will be the same. Offset and BS are just two different ways of measuring the same thing. BS is the distance from the mounting surface of the wheel (where it bolts to the hub) to it's rear edge. Offset is the distance from the mounting surface of the wheel to it's center.
Old 11-26-2009 | 12:32 AM
help
I still cant under stand that Off SET and BS I dont know,But here is another one I would like to ask about
20x9, 6 on 135mm Bolt Pattern
Backspace = 6.25 in.
Max Load = 2200lbs
Finish = Chrome
Hub Centric = Yes
Offset = 32mm
How far will that stick out,from factory,Im looking for the factory look,and would I need the Leveling kit with this rim and the 275/60/20 tires or will I be ok with the factory height...Thanks again Guys
Old 11-26-2009 | 11:43 AM
wandell's Avatar
Those will stick out 0.75 inches farther than the OEM wheels.
Old 11-26-2009 | 12:57 PM
Indo's Avatar
https://www.rsracing.com/tech-wheel.html
That website helped me understand backspacing and offsets. Nice to see pictures too. It's really not all that difficult to understand once you get it. Hope that helps.
Old 11-26-2009 | 02:25 PM
Azblu's Avatar
Very Helpful....Thank you!
Old 12-01-2009 | 12:07 PM
Ok one more time please i think
I STILL CANT UNDERSTAND THE BACK SPACE **** AND OFF SET,I GUESS ITS ME LOL,WELL I GOT THE TIRES AND IM NOW LOOKING AT THE
Size 20 x 9
Offset -12
Part Number MO958-29063212N
Hub Bore 87.1
NOW NEED TO NO IF I GET THESE RIMS THAT THERE HAVING A 1 DAY SALE ON TODAY WILL I NEED THE LEVELING KIT ON MY TRUCK AND HOW FAR WILL THAY STICK OUT,IM LOOKING TO KEEP THE WHEELS IN THE BEST I CAN..
MY TIRES ARE THE 275/60/20 LTZ THAY LOOK AWESOME
Old 12-01-2009 | 01:12 PM
wandell's Avatar
What backspacing is that?
Old 12-01-2009 | 02:48 PM
SmokeyBear's Avatar
This might help, my rims are 20x8.5 (virtually the same as the ones you speak of) with a -35 offset or 6.1 inch backspace (again virtually the same) The tire size is the same as your LTZs. I do have a 2" level kit but they would have fit without one. Here is a picture...
Old 12-01-2009 | 02:50 PM
SmokeyBear's Avatar
try this site too, play with the different setting for offset and you'll see the differences.
http://www.wheelsmaster.com/rt_specs.jsp
Old 12-01-2009 | 06:52 PM
svt4lyfe's Avatar
he means +35 offset w/6.1" BS....-35 would be sticking way out
not busting your *****, just clarifying
