05 2wd Screw - 33" tires on stock 18" wheels
Perhaps a few of you guys have responded in the past and, to be sure, I have reviewed countless posts...however, my question:
Given the fact that the middle will wear if too wide a tire is on a stock 18" wheel, what do you recommend I go with as my tire?
2005 2wd Lariat with 3" spacer level in front and 1" block in rear. Currently, the tires (i believe the relative i bought it from had 255/55/18 on it) are too small.
recommendations? I have heard and read that with a leveled 2wd, you can go no larger than 33" and that with a leveled 4wd, you should go no larger than 35".
looking at going with:
285/65/18 - BFG AT KO's
275/70/18 - Toyo AT's (cheaper)
or even 285/75/18 Toyo AT's** I would like to go this route, but concerned that even with it level out with 3", maybe cutting it too close.
anyone think that a 305/65/18 - BFG will fit and wear okay?
Feel free to give as much input as possible. Thanks.
Here is a link to a guy with a leveled 2wd running some 285's. Look in his gallery at his white truck, I think you will like them. https://www.f150online.com/forums/me...3-blkbuty.html
Go with the 305's.
2.5 spacer w/ 285's
2.5 spacer w/ 305's
I originally bought a set of 285's that wouldn't balance out so when they did the replacement I paid the extra money and went up to 305's. The 285's were too small and just didn't look right to me. I am way happier with the 305's.
Fry
2.5 spacer w/ 285's
2.5 spacer w/ 305's
Fry
I have 275-70-18 Continentals on my 2004 4x4 with a 2.5 level in front and nothing in the rear. These tire are a HT tread, but fit fine, no rubbing, infact I had them on before I put the level kit in with no problems. From lock to lock there is at least a 1" clear in the front of the tire and almost 1.5" behind the control arm. Good luck, I'm getting ready to put 285-75-18's on my ride, with aftermarket wheels, hopefully no problems.
