will this work????
Old 12-03-2009 | 02:12 AM
Keaka06F150's Avatar
will this work????
I'm pretty new here, have been looking around the forums though and noticed quite a bit of guys have the moto metal 951's on here. i recently found a set of 20x10 951's that i believe have 4.5 in backspacing, and i wanna say -12 offset?
anyways my question is if i can run these wheels with toyo m/t 35x12.50s on a 2wd 2006 f150? im looking to get the skyjacker 6" lift kit with the rear springs. im pretty new to this, so any information will be greatly appreciated!!!! thanks
Old 12-03-2009 | 04:36 AM
anyone know???? greatly appreciate any help
Old 12-03-2009 | 09:40 AM
anyone??
Old 12-03-2009 | 01:19 PM
wandell's Avatar
Since you have a 4x2, the wheel is 10 inches wide and the wheel's backspacing is so shallow, I'd add a leveling kit to the 6 inch Skyjacker kit if you want 35x12.50's. You may still have to do some minor trimming.
Old 12-04-2009 | 03:23 PM
oh i see, thanks wandell i appreciate it. im kinda new to the tire fitment and all this, what would be the biggest i could go with just the lift? would it be better to get the 20x9? because they make that as well, i would just like my wheels to stick out like 06 ford's so i thought i need the 20x10. thank you!
Old 12-04-2009 | 06:49 PM
wandell's Avatar
If you don't want to add the leveling kit to the 6 inch lift, I'd go with a 9 inch wide wheel with 5 inches of BS. Keep in mind, the front end will be pulled apart anyway so it won't be anymore labor to install a leveling kit. You will just be out the cost of the leveling kit ($60-$100).
Old 12-05-2009 | 12:37 AM
oh i see, yeah that wasn't the problem i know that the rear springs are only 4 inches i think and i do not want the front half higher than the back. the leveling kit would make only the front higher correct? if it works for the back id have no issues with it. sorry i know what the backspacing is but do not really understand it too much, i will look into it. but i think the they are 20x9 with 4.5 in? not too sure ill check. thanks man i appreciate it
