Tire Help For snow
Tire Help For snow
Hey, I need new tires for snow. I have a 2005 ford f150 4x4. I have the 2.5 leveling kit on it. It still has the stock xlt rims. I need tires for winter. What should I get. I see alot of people with the Nitto T/Gs. I want something to do good in snow and cheap because next summer I am going to be putting on 20 MM951s with a different tire obvisouly. So these xlt rims and tires will be for winter. I am also puttin a 6in lift on it so I dont want these tires to be so small they look stupid for next winter. What size do you recommend. 285/70/17?
Winter tires
Best suggestion here is do a search on Winter or Snow and you'll get all kinds of threads on this subject. Then it's a matter of taking your pick on which ones you like and can afford. One thing to consider when making your selection is the type snow situations you'll be driving in: urban vs country (ice/slush/packed vs powder) and do you want to float on or cut through the top to bite into it.
The best winter rubber compounds do not hold up well to dry, warm pavement. If you will only be running the tires in the winter, I suggest a full-on winter tire. Just because it has the snowflake icon on the sidewall does not mean it is a full-on winter rubber compound.
If you want an all-around tire that works pretty good in the snow, I've been impressed with the Goodyear Wrangler Silent Armor. I got these for less than $600 installed at my local Ford dealership but they do not have a true winter rubber compound so they can be run year-round. They DO have the snowflake emblem so they satisfy the letter of the law when it comes to winter tire road requirements without needing to chain up:
255/75/17
