Toyo MT or Cooper STT
Well, mpg for sure, lost about 3.5-4mpg. I lost alot of noticeable power. When the truck was towing , even small loads, and sometimes empty it would struggle bad when shifting into od, sometimes making a slight metal clanking sound and slight vibration. I had them in 285 75 18's. After two years with them I gave in and sold them and bought nittos in 33" and the truck has gained back everything the toyo's took away. The ones I had weighed 75lbs a piece and were 35" tall x about 12" wide.
[IMG]
[/IMG]
[IMG]
![](https://www.f150online.com/forums/members/maxout05-albums-truck-parts-picture29327-285-75-18-35s-toyo-mts-sold-them-cause-they-were-too-big-power-truck-killed-my-mpg-towing-power.jpg)
Agreed they were great in every condition. But there was obvious issue with some sort of drive line struggle with mine, as I talked about in my above post. That and 9mpg were the end of them for me. I miss the look, but thats it. The were way too heavy. Not every size for them was as heavy as mine though, you gotta look it up on toyos site.
I actually was shopping the same two tires in a 305/70 16. Ironically, the price difference when I checked was less than $200. Given the Toyo's E rating, that's a no brainer. Cooper was doing good with this tire back when it was the economical choice, but for the same price there's no real good reason to pick it over the Toyo. With such a small price difference, the only reason I would see someone picking the Cooper over the Toyo would be completely based on looks...if you by chance liked the Cooper better.
