help deciding between 285/72 or 305/70...
Old 02-04-2010, 10:06 AM
pkent03F-150's Avatar
hey guys i need help deciding on a 285/75/16 and a 305/70/16 tire...the price difference is $20 a tire...so 80 a set. Is there a big enough difference between the two?
and also what brand should i go?
Toyo MT or BFG MT
Old 02-04-2010, 12:01 PM
wandell's Avatar
You are basically comparing a 33x11.50 tire to a 33x12.50 tire. If you are using the OEM 16x7 wheels, the 285's will fit the wheel better. Both the Toyo's and BFG's are excellent.
Old 02-04-2010, 12:24 PM
i have 16x10 in wheels on my 03 f-150...i have heard that toyos will last longer, and would like to get 40000 miles out of the tire. since they are the same price i am torn btw the two, i like them both. i have 285/75/16 on my truck now, bridgestone dueler at. wandell youre the one that helped me get that setup and told me theyd fit with the 16x10. ive enjoyed that setup, but i am wanting to go to a mud and bigger...
Old 02-04-2010, 12:28 PM
thejake1989's Avatar
either way you go the toyo or the km2 will last you a good while and forsure id go with the 305/70/16. unless your getting close to rubbing with the 285"s
Old 02-04-2010, 12:35 PM
i want the 305/70s, but i was reading the specs on the 285/75 and the section width in the toyo mt was 11.6 and in the 305/70 it was 12.2. so i wasnt sure if it was worth dropping an extra 80 bucks to go up to a 305/70....
Old 02-04-2010, 12:37 PM
the km2 is extra 30 each for the 305's at discount.
whats your suspension setup?
Old 02-04-2010, 12:43 PM
3 inch body lift...at a local tire shop the guy gave me the prices in the 305 toyo and bfg were the same. the 285 in toyo was $260 while 305 was at $280...so i was just trying to figure out if the money was worth the 305? i have 285 now
Old 02-04-2010, 12:45 PM
absolutely worth it for that prices. 80 bucks is chump change when it comes to how much these tires cost.
my only concern would be rubbing
Old 02-04-2010, 12:57 PM
i will have to do a tiny bit more trimming...but the 285s fit well and look good. how much wider is the tread on the 305 to 285? yea it would be worth it..ill make them fit
Old 02-04-2010, 01:01 PM
i like your style haha
Old 02-04-2010, 01:03 PM
haha yea man...plus theyll look even wider with the extremely aggressive sidewalls on the toyo mts...those tire will fill the wheels out better
Old 02-04-2010, 01:04 PM
yea. depending on how mine takes the 35's i may end up at that size also
Old 02-04-2010, 01:09 PM
yea i think its a good size...a 33 inch by almost 12.5..i would put 35s on mine but they wouldnt fit on my rims...
i def want to go a little wider and the awesome tread that toyos have. you should be able to fit 35s on those wheels
Old 02-04-2010, 01:13 PM
i can get 35"s on the wheels just the width is my concern. you can get 35's on your wheels just not the truck and being able to turn haha
Old 02-04-2010, 01:20 PM
yea man id try the 35s on yours..a buddy of mine had 35s on his stock wheels and they worked just fine, he had the bfg at. they did wear more in the middle of the tread but were with the wheel.
Quick Reply: help deciding between 285/72 or 305/70...
