Backspacing and width of Factory 18" FX4 wheels
How would this set up look or work on a 06 FX4 with stock suspension?
ATX ARTILLERY (with BFG All Terrain T/A KO 285/65-18)
Size: 18 x 9
Offset: -12
Backside: 4.53
Would the tire stick out from the fender, if so, by how much? I’m trying to keep the original look of the truck but with a little bigger tire and some new rims.
Size: 18 x 9
Offset: -12
Backside: 4.53
A good rule of thumb: 9" and or offset that is negative will usually need at a minimum a 2-2.5" lift up front with conservative tires, and probably a lift if the tires are bigger. This is an ATX Vice in 18 x 8.5, +30mm offset on my truck. Even this comes quite a bit further out.
Dont mean to thread jack here but im looking at getting a set of XD addicts in the 18X9 with the +18 offset and 5.71 backspace. Im going to run a 35 X 12.50 with a 2.5 leveling kit. I have run the 35s with the stock wheels and some rubbing so hopefully this wheel will fix that. Any thoughts?
I'm not 100% sure, but i don't think 5.71 is enough backspacing on a 9" rim with out trimming. I may be wrong tho. I just wanted to compliment you on your truck, it's reall nice.
