Metal Moto 951's
Metal Moto 951's
I am looking at the Metal Moto 951's (18x9) and was wondering if anyone has any experience with these wheels?
i am looking at a 2" leveling kit with Nitto Terra Grapplers as well (325/60/18) - will there be any problem with this setup?
If anyone has any advise / pics / or anything else, please let me know.
Thanks everyone!
Scott
Thanks everyone!
Scott
Thanks everyone!
Scott
Thanks everyone!
Scott
Oh and BTW, the leveling kit will be fine with those tires if your truck is 4x4.
4 1/2" backspacing (or -12mm on a 9" wide wheel) will stick out more than stock. If you're looking at 9" wide wheels and want to look closer to stock then stick with a +18mm or higher offset. On the other hand if you're wanting a more aggressive look try to find wheels with a 0mm or a negative offset.
luner,
the only rubbing that i had came from the side tread on the nitto mud grapplers. an the only time it rubbed was when i was turned as far as i could left or right so therefore i did minor trimming( and minor i mean i cut off a piece of plastic no more than an inch squared of both sides.. im sure if i wouldve picked another tire i would have had no problems whatsoever..
-Rich
-Rich
