TPMS Bands
Factory bands are not reusable but aftermarket bands are. If it was factory tires/wheels that were removed then you would have had to buy new bands. If it was aftermarket tires/wheels that were removed it just depends on whether or not the original shop that installed them used OEM or aftermarket bands.
They could have. Did you have the sensors removed from your factory wheels/tires when you swapped the first time? Do you remember if you had to buy new bands and sensor cradles? If you did buy them the first time around chances are they left the OEM band and cradle in your OEM wheels and just reinstalled the sensors when you swapped back.
FYI tire rack as well as Saleen sell bands and cradles. I think Saleen had them cheaper than tire rack did. Also search on Ebay for the Sensor tire programmer tool. I bought this off a guy (i think he worked at Ford) on ebay and it allows me to program the sensors to my truck. If you don't do this you will still have the TPMS light on even though you do have sensors.
