How to service brakes
We just debated the rotor replacement issue in this thread. You'll know they're bad if they pulsate when stopping (likely warped) or if you can see visible channels or pits in the rotor surface. Likely won't happen if you use soft(ish) pads and replace promptly when needed, clean the rotor surface each time and bed in the new pads properly.
Semi-metallics are good. I mean "soft" in comparison to harsh ceramic materials. They'll help your rotors last longer. They will still feel firm to the brake pedal, but semi-metallics take more of the friction reaction, whereas ceramics put more of the friction on the rotor (thus eating them up more rapidly).
IMO you should be fine to replace the pads without turning rotors, as long as they aren't damaged and you do it before all the pad material runs out. Make sure to clean the rotor surface well with brake cleaner and a rag, and follow pad mfr.-recommended pad bed-in procedures.
