will these wheels work?
http://4wheelonline.com/Products.asp...oductId=127795
wanted to get these in 16"x8" with 305/70/r16 tires. ive got a spindle lift which makes the tires stick out a lil farther. i wanted to know if the -11mm offset will fit good?
First things first...put what they are going on before these old dogs get ahold of you!
I assume if you are getting a 16" wheel you have a 03 or older truck? If you are a 4x4 and you are putting on a 32.8/12.00/16 , i couldnt imagine why they wouldnt fit.
I dont know as much about the pre-03 models though. Look for wandell, hes a wheel and tire guru! So anyway post your setup and theysmart guys will come and get you straightened out
