getting 305/70/16s in trade will they fit stock wheels?
Why do you like a body lift but not coil spacers? The general consensus is the exact opposite around here. I’ve run coil spacers on two trucks with no problems at all.
I’m running a 305/70/16. Granted I have about 5"s of lift, aftermarket wheels and the spindles push the tires out far but they rub ever so slightly on the fender still. If you did decide to go to those tires latter you’d need a wider wheel and some lift.
I also have a 4x2 with 16 x 7" wheels. I've been reading around and it seems tire size is affected by front tire steering clearance. I'm just curious if anyone has put bigger tires on the backs. I'm thinking 265/75 R16 on front and 305/65 R16 in back. They are about the same height so it won't look funny and I'd get more traction with the drive tires. My dad has a 99 250 HD with 245's in front and 305 maxxis mudders in back. Any thoughts?
