Caliper pistons
Caliper pistons
Alright this one may be a bit ofa silly question, but I have to ask it...
first: 2002 SCrew, 2WD, 4.6 windsor, 120K
Doing a front brake job on the truck, decided to replace the hubs and wheel bearings. Been having a little trouble with pulsation but nothing HUGE. Pulled the calipers and tried to compress them with a C-clamp and it was ridiculously difficult. figured I'd cycle the brakes a few times to see it I could free them up but only one of the pistons actually moves when I push the brake pedal. Checked the driver's side and it does the same thing....
So the question I have is...they should both move, right? I mean, why have two pistons if only one of them moves...?
Thanks in advance.
dK
Thanks in advance.
dK
They should both move. I ran into a similar problem on my 98, only single piston calipers, one side would not retract. I ended up replacing both. You may be able to work them both withe C clamp and get them working. Other wise replace or rebuild. Slight pulsation could be becasue of uneven pressure on the pads.
