new wheels and tires, now rubbing
So, I have a 2005 FX4.
I got new wheels: http://aewheel.com/wheels_detail_specs.cfm?id=25
17x9 offset is -12mm, backspacing is 4.47
I got new tires: the nitto dune grapplers
285/70/17
Had them put on yesterday, I love the way they look, but they're rubbing when I fully turn. My question is if I put a leveling kit will it prevent this? Any other ideas would be greatly appreciated.
285/70/17
285/70/17
285/70/17
any reccomendations on levelers?
http://www.4wheelparts.com/Lift-Kits..._pn=EXPLL-2050
http://www.4wheelparts.com/Lift-Kits...t_pn=SKYFF25MS
http://www.4wheelparts.com/Lift-Kits...n=DAYKF09111BK
I'll go snap some pics and have them up in a few.
I am running a 2 1/2" autospring in the front and a 1 1/2" add-a leaf in the rear also autospring. I ordered them as a kit off of ebay about 2 1/2 years ago and haven't had a single problem with them. By the way I added the add-a leaf to the rear because I have a top on the truck that I haul hunting and fishing things in all the time and I don't care for the cali / bull dog look.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
On my truck it put the rear maybe an inch higher than the front, Not the 70's hot rod rake but what a truck should look like. As for install it was very easy, i did one side at a time. Put the truck on jack stands, put a jack under one side of the axle and unbolt the u-bolts. Let the jack down enough to put the add-a-leaf in and jack the axle back up and reinstall the u-bolts. I can't remember if mine came with new u-bolts or not, I have put on about six different lifts in the last couple years and they see to run together in my mind. I did the front and rear of the truck in about three hours or less and this was my first time to do one on a f150. By the way we have three f150s in my family and everyone agrees that after I did the level and add-a-leaf my truck drives, handles, rides and tows better than any of the rest.
