tires for 07 HD (22")
I need to get new tires for my 07 and am trying to sort through my (limited in this size!) options. I have only a few to pick from like the cooper zeon xst and the OEM pirelli's (and some kumho's i think?) in the 275/45/22 size but on the toyo site they show some proxes that are available for my truck (using their tire finder) in the 285/45/22 size.
So my question is firstly what tires are you guys running on your 22s, how do you like them....and does anyone have pics of an HD with 285/45s so I can see how they look?
thanks!
thanks!
Not sure if these will fit a stock wheel but I highly recommend the tire. http://www.treadepot.com/tire/01402.html
im running toyo at's 305/45/22 its a 10 ply tire ride is a bit rough but i beleive its because of my stock shocks which i should be upgrading soon. i highly recommend this tire ive gone off pavement a couple of times mainly just ranch roads and such and its done just fine. the traction is also pretty good on this tire, ive had them on for about 8000 plus miles and still look pretty new and wearing nicely if you keep up witht he rotation. im thinking of buying the toyo mt's for my next tire they just came out with a 33 for 22's check those out if your looking for a more aggressive tire. i also believe nitto terra grappler has a 32" tire aswell. hope this helps some good luck!!!
