Tires and Gears
Old 02-26-2010 | 09:17 PM
BlackFX4inTN's Avatar
Tires and Gears
Ok, I'm halfway through with my rim and tire purchase and I have a few questions before deciding what size tire to go with. The 18x9 Rockstars are on their way, and in the mail,but I'm trying to decide on whether to go with 35x12.50 or 33" Toyo MTs. BTW this is going on my 07 with a 2.5" AS leveling kit.
I'm not exactly sure what size gears I am running and was wondering if someone could link the door code deal to so I could find out. With that said...
Which size tires should I run depending on the size of the gears? I want to run 35's but if I were to have 3.55 gears, would that be a no no? And if so, I guess the answer would be to go with 33's, eh?
Also, as far as trimming, with the leveling kit and backspacing of the rims being 5mm, what kind of trimming are we talking about here if I were to go with 35's? I know if I were to go with 33's that there would be no trimming. I was told that I would have to trim out half of the fender well twords the engine compartment. Does this sound accurate? Anyways, thanks in advance for your help.
Old 02-26-2010 | 10:37 PM
wandell's Avatar
You are gonna have to go with 33's. Also did you mean the BS is 5 inches? It would be impossible for the BS to be 5mm because the wheels would stick out almost 5 1/2 inches farther than the stock wheels.
Old 02-26-2010 | 11:59 PM
yup 5 inches, IDK what I was thinking stating mm.
Old 02-27-2010 | 12:04 AM
I just discovered I have an H9 door code which is 3.55 LS. I guess it's 33's for me.
Old 02-27-2010 | 12:05 AM
For others to use as a reference. Here is the decoder table that I was looking for earlier.
http://www.ford-trucks.com/article/i...r_Decoder.html
Old 02-27-2010 | 06:55 AM
sonic69's Avatar
Or you could just change them gears.
Old 02-27-2010 | 10:39 AM
wandell's Avatar
Yes, you are gonna have to go with 33's.
Old 02-27-2010 | 11:34 AM
I was under the impression that FX4s were supposed to come with bigger gears. I feel kind of cheated. I'm not going to change gears unless I were to go with a 6"+ lift.
Toyo makes a 275/70 18 tire which they claim to be 33.6" but the tire calculator I use says that they are 33.2 " and 10.8" wide. Is Toyo's version of this tire actually bigger at 33.6 or are their measurements accurate?
If I were to go with their 33x12.50, would that width be an issue versus the width of the above said tire at 10.8? I would much prefer a wider stance but if the 33.6" is accurate I would rather go that route.
Old 02-27-2010 | 04:58 PM
brianjwilson's Avatar
Why do you feel cheated? It is your own fault that you didn't look before hand.
Still that sucks, but it is very easy to look at a door jamb when you are looking for trucks.
Anyway, go with a 33. Not only is it going to be terrible to run a 35 with 3.55s, but fitting a 35 will be tough with those wheel specs. Don't worry, the 33s will look good on aftermarket wheels anyway. I would go with a 12.50 though, a narrow tire will look silly (IMO) on a wide aftermarket wheel.
Old 02-28-2010 | 03:02 PM
Yup, that is my fault for not looking but I guarantee you it wont happen again. Anyways, I did order the 33x12.50's and they will be here on mon while the rims wont arrive until tues. Hopefully, I can get these things on tues. Thanks for all the help.
Old 02-28-2010 | 04:09 PM
With 18x9 wheels with 5 inches of BS you would have a good bit of rubbing running the 35x12.5x18 MT's. The 33's are a better choice also with a 3:55 rear end. I'm running 33.5x12x17 (295x70x17) Toyo MT's on 17x9 with 5 inches of BS and have a good bit of clearance in the front. Remember the Toyo MT's have large side lugs and are taller and wider usually then the same size in an all terrain version.
Old 02-28-2010 | 04:14 PM
They will look close to this size on your truck but 18" wheels and tires.
Old 02-28-2010 | 08:18 PM
Thanks Paw Paw. Makes me feel much better about my choice. I'll post pics for those in a simliar situation as me, like you did. Hopefully it will help them make a more educated decision as well as realize just how good the 33's will look. I'm sure that the size of gears one has, is something a few don't consider before purchasing tires.
