Will these Tires Fit?
Old 03-02-2010 | 05:17 PM
the_ojibway's Avatar
I am looking to change my tires and rims for a winter /summer set. I have a 2006 King Ranch SCREW with a 6" Fabtech lift. I also have the edge Evolution that will fix speedo ratios. Any way.
Current Setup 22" Momo rims,
Nitto Terra Grappler 325/50/22
Height 34.84
Width 12.95
Looking to switch too for spring/summer and will they work 15" is pretty wide
Mickey Thompson Classic II Rims 18x10
Mickey Thompson Baja Claw Radial 375/50/15
Height 34.24
Width 14.76 (Calculated)
These tires are brand new. The rim and tire size has been discontinued by Mickey Thompson. Does anyone see any issue I would run into with width. They are almost 2" wider than what I have now, but I cant find out any info on the Rim for back spacing.
Thanks for any help and all your posts.
Old 03-02-2010 | 10:49 PM
wandell's Avatar
I believe that wheel has 6 inches of backspacing. It would be a tight fit because of the 375mm width.
