1997 F150 2WD ABS Problems
Hello,
I am having a problem with the ABS light coming on periodically.
Based on suggestions on this board, I replaced the rear ABS sensor.
I checked resistance on the old sensor, 1.6K ohms. New one was around 2k ohms.
The new sensor did not take care of the ABS light. Light is still on.
I then checked resistance on the front wheel sensors. Both had around 2k ohms.
Is there anything else I can check to determine where the problem may be?
Thanks guys.
Dave
Thanks guys.
Dave
