Correct Tire Pressure
What amount of tire pressure is everyone using? I just bought 275/70/18 BFGs and they put 60 lbs in it. Is that alot? I usually ran 35 in my old truck with larget tires. Any suggestions?
2006 Screw King Ranch
275/70/18 BFGs
2" AS Level kit
Volant Cold Air Intake
Borla Exhaust
275/70/18 BFGs
2" AS Level kit
Borla Exhaust
you can go by the max inflation pressure stated on the sidewall of your tires. if they say max 80, 80 will get you the best fuel mileage tho the ride may be a little harsh, you can decide for yourself where you like the pressure down to around 40-50 just keep an eye on the wear pattern if the edges start to wear funny you have probably gone too low.
FWIW I run my "E range" tires at 75psi all the time.
