Better Pictures of new Trail Grappler upgrade
Ya, the stock FX4 Rims are bad ***. I debated getting new wheels but thought I would rather save the money and put it toward the tires I wanted and keep the stock rims, which I love!
Weber, truck looks great man. I see those are 295/70/18's. I will be getting the same exact size on my '09 FX4, but will be going with the Terra's instead. Those tires you have Load Range E? The Terra's only come in Load E in that size. Was wondering how the ride was. Also, I assume you have at least a leveling kit, how much of a lift and what kind?
Ya they are load range E. They ride great and much smoother and quieter than I expected out of a MT. I have a 2 1/2 Hell bent steel level kit on it. I did have some rubbing at first but I swapped the tires around so the v-shaped lug pattern faces out and the rubbing has stopped it still touches at full lock but no bumbing and rubbing as it goes around and hits each lug like before.
I am going to put in a full tank probably tomorrow and then try and drive normally for a full tank and see what I get mileage wise. I will give you a heads up when its empty!
EDIT: Here is the link with the measurements: https://www.f150online.com/forums/su...2-5-level.html
