front brakes smell hot
i just recently had new rotors , brakes and calipers and i put new brake lines on it and when i drive it the passenger side get hottoer then the driver side and also smells like its burning . so my question is what else can it be that is causing it. the truck isnt pulling when i apply the brakes so i cant figure it out
2004 Rotors
I had my front rotors turned. Before hand the guy say's "those are hard to do". I assume because the center is sealed bearings. Well when all is said and done when I brake the front end shimmies and the pedal goes up and down a little. Is there a special trick on doing the rotors?
Thanks!
David
Thanks!
David
OP - you should check and fix the problem.
Thanks!
David
Thanks!
David
