Tire Advice
If your'e going to be beachin' it, for sure, listen to Paw Paw. 305's. You might can even find a 33" tall 325 for a 17, I know you can for 18's, but I'm not positive.
So I did some research.
Are you leveled? If so, I don't think you would have a problem fitting Nitto Terra Grapplers in a 305/70-17, which is 33.98" tall.
And BFG does make the 305/65-17 AT, that would be a great choice also.
Those ought to be OK on a stock height truck with 8" wide wheel's. May as well get it leveled and go with a little larger tire because you will probably regret it later. Think the truck is sick you ought to see the driver!!
The driver??? Unless its a hot lil brunette Im not interested hahahah
