need help with wheel offset on 24's
I have a 2006 F-150 Screw lariat 4x4 that has been lowered 2" in front and 3" in the rear. I have factory wheels right now but I want to upgrade to 24's. I somewhat understand wheel offset but not backspacing. The wheels I am looking at online are 24x10 with a 25 offset. The tires are 305/35 and I am concerned about buying them online and finding out they rub on the fenders. Tirerack.com only has 3 wheel options for this truck, a 24x9.5 with a wheel offset of 15mm, 25mm or 30mm but that wouldn't take into account the truck being lowered. I am hoping someone would know from experience if the 24x10 and 25mm offset is going to work for me or not before I buy them and ship them to me.
That is indeed a 6.5" backspace on those wheels. The tire and wheel combo will be approx 32.4 inches tall and 12.1 inches wide. Pull a front wheel off (backs will almost certainly fit) and start measuring. Maybe make a cardboard template to those dimensions to help you visualize how the wheel will fit. Don't forget to measure at full lock as well. Good luck.
Backspacing is probably an easier measurement to use when determining if a particular wheel is going to fit in the wheel well properly although most wheels advertised online use offset measurements. Would it be safe to say that if a 10" wheel has an offset of 25mm off dead centre. 25 mm is pretty much an inch. At dead centre of a 10 " rim the backspacing would be 5 " and then the 25 mm (1") offset would change the backspacing from 5" to 6"?
