New tires and rims are on!!!
20x8.5 Liquid Metal Magmas
275/55/20 Cooper Zeon LTZ
Got the package from Discount Tire Direct.
I kinda wish I can gone bigger like 33s but I don't have a leveling kit yet so that will be the next thing on order is the 1.5" autospring.
Here is a pic of the truck before
After
After
Looks good, I think its a good size, if you go with the 1.5" I think it will still look good. If you with a larger level they might look a little small. You could always leave the level off, once you wear out the tires go with a bigger set and a 2 or 2.5 level. In the mean time leave the stress off your ball joints.
OR
Get some leveling shocks, leave them at stock height or so, then once you get new tires turn them up???
OR
OR
OR
Its not that bad as long as you do not go above 2.5". Regardless you dont need it now unless they are rubbing. Unless you have already replaced the shocks chances are you will need new ones b/f you need tires again; if thats the case get some leveling shocks and you can adjust as needed if you go with bigger tires in the future. Once again, looks good
