Moto 951's
well if the wheels are 6x135 they should fit no problem...the question is, what type of backspacing/offset do they have and what size tire do you want to run??? i had moto metal 951 20x9's on my 07 4x4 lariat without a level...the backspacing was 6.18 and the offset was +30 and I ran 305/55/R20 terra grapplers...only had to trim about a 1" triangular piece of inner fender (closet to the cab) with a dremel....other than that, no rubbage even at full lock...hope this helps
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
well if the wheels are 6x135 they should fit no problem...the question is, what type of backspacing/offset do they have and what size tire do you want to run??? i had moto metal 951 20x9's on my 07 4x4 lariat without a level...the backspacing was 6.18 and the offset was +30 and I ran 305/55/R20 terra grapplers...only had to trim about a 1" triangular piece of inner fender (closet to the cab) with a dremel....other than that, no rubbage even at full lock...hope this helps ![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
