New Trail Grapplers, PowerSlot Rotors, Hawk HPS
Old 05-07-2010, 08:14 PM
russ10screw's Avatar
Talking New Trail Grapplers, PowerSlot Rotors, Hawk HPS
Ok. So yesterday was an exciting day. Finally got my new tires installed. The old Terra Grapplers had reached their limit right at 55,000 miles. They still had good tread left, but they started to "chunk". Anyway, I went with the new Nitto Trail Grapplers in 305/55/20. My brakes had been squealing as well and Brake Check had given up on me and vice versa so I took on the job of installing new PowerSlot Rotors and Hawk HPS pads. I painted my calipers black as well. Here are the pics:
Before with Terra Grapplers:
After with Trail Grapplers:
So far I'm a fan! The brake job took a long while since I was painting the calipers at the same time. I was really happy I went with black, since it matched the rotor as well as I didn't have to be quite as **** about the paint job and masking things off. The brakes are much much better. When I removed the old ones, the rear pads (all 4) had cracked right down the middle.
The tires are pretty sweet. These are my first mud-terrains so they are quite different. They are quite a bit noisier in my opinion. On the highway is where I notice it the most. Like I said, I've never owned a mud-terrain so I have no point of reference as to whether they're loud or not. Speaking of, has anyone on here gone from the Toyo M/T's to the Trail Grapplers? I'd be curious what the comparison is. Other than that, they ride fantastic. And they look great. Whats funny to me is Nitto's idea of the "aggressive" sidewall is not nearly as aggressive as the other side. The side lugs are much beefier on the "normal" side. I had asked for the "aggressive" side to be installed out, but they did it backwards and I'm actually glad they did. I like this side better.
Anyway, let me know what you think. Thanks to everyone on this site that has answered questions and posted how-to's and everything else I take advantage of on a daily basis.
Old 05-07-2010, 08:25 PM
mdhawkin's Avatar
I like!!! Good work. Just curious is your driveway unlevel, because the first pic your truck look like it has a lot or rake, but the gaps between the front and rear fenders dont look too far off?
Also, I have owned other M/T's before and these compared to others ride great.
Old 05-07-2010, 09:01 PM
Man that look's great!
Old 05-07-2010, 09:32 PM
Untamed302's Avatar
Wow...what a differance!! Looks great
Old 05-07-2010, 10:25 PM
Thanks and yes my driveway has a slope to it. Hate it. Wish it were flat. The truck is pretty much level though. By the way, what air pressure are you running and is that what you would recommend for me here in San Antonio?
Thanks for the compliments to everyone else too!
Old 05-07-2010, 10:42 PM
With the hot weather coming up I would run 45 psi. If too rough drop down to around 42 psi and see how they ride. I wouldn't go below 40 psi.
Old 05-07-2010, 11:22 PM
hawg_man's Avatar
Looks great russ! I am always impressed with how good shape your truck is in
Old 05-07-2010, 11:27 PM
Dude that looks amazing... so awesome
Old 05-07-2010, 11:49 PM
PawPaw, thanks I'll confirm my pressure and keep that in mind.
Hawg_Man, thank you sir. I try my best to keep it in good shape. There are some little things that show up after 8 years that drive me crazy, but its been a great truck.
TruckGuy24, thanks for the compliment!
*Random question. I've posted quite a bit, but have no idea how to quote multiple people in one reply. Any help would be appreciated. Thanks!
Old 05-07-2010, 11:53 PM
Click the button with + with the " and when you select the last one, hit the quote button instead
Old 05-08-2010, 12:01 AM
animated_zombie's Avatar
I'm currently running the same brake setup!
(other than my ABS issue...) I love 'em too!
Your pictures look super clean btw!
Old 05-08-2010, 12:02 AM
07BlueLariat's Avatar
Nice rims man.. do you have any rubbing? what is your suspension set up? Thanks
Old 05-08-2010, 12:05 AM
thejake1989's Avatar
Sweet man I love those tires. What the brake setup run you just for the front.
And I try and keep my bfg's between 42-45 psi
Old 05-08-2010, 12:20 AM
4x4wolf's Avatar
Looks very good, I love the stance of your truck
Old 05-08-2010, 01:12 AM
mdhawkin's Avatar
Running 50 now, but will prob drop down a little as its starting to get pretty warm here. Will prob run ~46-48.
Quick Reply: New Trail Grapplers, PowerSlot Rotors, Hawk HPS
