Will an 18 x 9 wheel work on a 15.50?
Hello everybody I am looking at getting a set of 18 x 9 DC-1's and im looking to put them on a 39.5 x 15.50. Will they work with that wide of a tire? Ive had a 16 x 10 on a 15.50 but not an 18 x 9. I'm not sure the backspacing and all on the wheels. I just wanna know if they will fit or not. Any help would be greatly appreciated. thanks!
Holy resurrected thread Batman!!
I have the same issue, I have 36x15.50R18 tires that I cannot find wheels for. I can't find any 18" wheels wider than 9". Does anyone know where to get an 18x10 or 18x12? My tires would look/fit even worse because there is even less sidewall on my 36 18's than the previously mentioned 38 18's.
Thanks in advance for any help for this newbie to the forums.
you just got to shop around. i just did a lift kit and the guy brought me 18x12 rockstars mounted on 38x15.50 to put on his truck. they are out there. the problem with running that size tire on a 9" wheel is because the sidewalls are not big enough to allow flex which means you are going to have more bubble in the center of the tire and you will be changing tires faster than you want too
