Way past due!
Way past due!
I desperately need to replace my pads and probably rotors too. Now instead of forkin up a ton of money to have a some guy at some shop tell me what I need I figured I will ask the real experts which will in this case be you guys.
I live in south Florida so mountains hills grades of any kind are not a factor and my towing is just about every 6 months (27 Contender). So, what is the best set up for the money? I dont want to get all fancy with cross drilled rotors and what not but considering no one in Miami can drive worth it be nice to slam on my brakes and not slam into the who just cut me off. So i guess what I am looking for is a happy median between performance and price!
Thanks in advance for you help!
Last edited by Bluejay; 06-02-2010 at 01:49 PM. Reason: Do not circumvent the language filter
PowerSlots are nice for an upgrade, or I've heard Centric has good stock (blank) replacement rotors. I also recommend Hawk pads like IDNC76, and many others on this site swear by Wagner ThermoQuiets. Whichever brand, I'd recommend using semi-metallic pads, not ceramic. Ceramics may give less dust, but they're harder on the rotors.
Between How-To articles on these forums and a Haynes or Chilton manual, you ought to be able to replace the brakes yourself. 2WD fronts are a little more "involved" since you have to mess around with the wheel bearings, but it's still very doable.
Good luck!
Good luck!
