Nitto Tire Wear
#48
Good gravy man!!!!.....did it feel like you were riding on bricks with that kind of pressure in them???? I've put mine at 45 all the way around but am thinking I should bump the front up to at least 50. If you've been running 75 with no problems, that takes away some of my hesitation
#49
yeah, I ride them to the very end They really didn't look like that till around 145,000, and the one pictured actually has 3 nails in it. Had to start putting air in the tire about every 2 weeks towards the end for a month and 1/2. If you look in my profile albums you can see the kind of blizzards we got this past winter that I was riding around on those tires in. I'm telling you those BFGs are some kinda awesome, IMO.
#50
I had 31x10.50x15 Nitto Dune Grapplers on my old Bronco II and I ran them around 46 seemed to ride the best and wear the best...so yea if I was running that on a BII you really should have more air in them. Also the other thing I noticed and you may want to take note of this....with the nitto grappler series tires they have thicker sidewalls, so any loss in air 10-20 psi will not be noticable as it would with an lt tire....they won't slouch and roll the sidewalls as noticeable....I learned always keep a tire gauge.
#51
I've been meaning to follow up on this thread. Since I rotated and bumped the pressure up to 50lbs, my wear is MUCH more consistent. Now the question is how low should I run them on the beach. My tires are 11.5 inches wide. Next time, I might not air down at all and just see how it does.
TO ALL YOU NITTO TG OWNERS, how do you feel about the constant rocks being picked up by your tires. It's driving me crazy. I've got scratches/dings down the bottom side of my truck AND on my brand new flares. My parents live off a gravel road and I camp alot. WHEN I can, I actually take the time to pick the rocks out of my tires w/ a small screwdriver before I go out on the road, but I don't always have time for that unfortunately. What is your opinion on this? Driving you crazy? Don't give a damn? ????
#53
The tire place and the dealer you went to are both freaking idiots who gave you advice that not only could have killed you, but at the minimum ruined your tires. I'd be pretty mad at them if i were you.
My nittos threw less rocks then any other a/t I've ever had so i'd have to say get used to it or get street tires, lol!
#54
Yea I had nittos in e range on my 05. You need to stay min 45 psi, the reccommended pressure for high end is 80psi, so you were running them 45 psi lower then whats stated on the sidewall, that was the problem. Thats equivalent to running a 50 psi tire at 5 psi, lol! When i had these tires nitto directly said to me min of 50 psi for my truck.
I hear you on the rocks. It's just hard for me b/c I'm really into detailing and keeping my ride looking good. It's hard when you have to "deal" with scratching your truck intentionally. OH WELL, I'll have to get me some paint and touch it up once per year or something like that.
#56
Hey BigSur, thanks for the update. I was wondering if it fixed your problem. I had Terra Grapplers on my last truck and also ran 35PSI for a wile, until I was told about it. I ended up running 42 psi most of their life. The ride was great, and they lasted me 42,000 miles with only a couple rotations. I sold the truck last winter and I see the guy still driving on them. I'm sure they'll go 50K. As soon as I have the cash, I'm putting 295/70/17 grapplers on my current truck.
#57
#58
Sweet looking i think!
#59
The 295's will fit. Here's my '05 with a 2" AS kit installed. And I'm running at about 50psi and they're wearing even. Got almost 4k on them so far. My tire man says the Nitto Terras wear as well as any A/T truck tire he's sold. I used to insist on Bridgeston Revos, but these Nittos are winning me over. The rock thing is a little annoying, but they've got pretty wide voids for an A/T.
#60
Well keep in mind the offset on the rim. Those rims probably have a +30mm offset, whereas mine has a -12mm offset, making clearance a little harder to obtain.
With the 2" kit and a 285/65/R18 tire, I had to trim the bumber valance to make it work. My guys says I need at least a 3" kit to make a 295/70 work. Hope you guys are right though b/c I don't want the 3" kit.
