275/70/18 no leveling kit
Old 06-07-2010 | 05:46 PM
gonefishin10's Avatar
Stock 04 FX4 4wd, is a leveling kit needed to run this size? I would like to run them without a level kit if possible
My search yielded yes and no...can someone please clarify
Old 06-07-2010 | 06:16 PM
mdhawkin's Avatar
They will fit, that calculates out to a ~33 x 11.
Old 08-19-2010 | 04:09 PM
Marauder491's Avatar
Did you get those tires on yet? I have the same year truck and am also thinking about running the 275/70/18. Would be interested in any pics of the tires. Any clearance issues?
Old 08-19-2010 | 05:24 PM
whip's Avatar
I'm going with the same size. Leveling kit is on order, but would like to see if it fits without.
Old 08-19-2010 | 07:28 PM
jdman12's Avatar
Hi you don't need a leveling kit to fit that size, I have the toyo mt's on a stock 2007 fit fine.
Old 08-19-2010 | 07:47 PM
JC2's Avatar
JC2
I had an 04 FX4 and had 305/55/20 terra grapplers and did not have a leveling kit. They will fit just fine.
Old 08-20-2010 | 06:29 AM
svt2205's Avatar
You can easily run 275/70-18's on a 2004-2008 without any issues. I've put over 97K miles on my 07 with this size without any contact, even with the plow.
Old 08-20-2010 | 08:18 AM
zxrider11's Avatar
Here are some pictures of my 2004 FX4 with 275/70-18 BFG AT TA KO's and 2" AS level:
Old 03-11-2011 | 07:10 PM
c1t1d1's Avatar
Here is mine bfg 275/70/18 at ko with no level. Also took picture of old tire next to new. Called bf goodrich and got recomended tire pressure base on my old tires rugged trail 275/65/18 useing the 32psi on door plate. BFG recomended 50psi .
Old 01-15-2012 | 12:55 PM
D-Mike's Avatar
I have an 05 fx4 with 3.73 gears. I plan on upgrading to this size, will I notice a change in fuel economy? Also how much off will my speedo be? Should I plan on recalculating?
Old 01-16-2012 | 08:24 PM
Fogducker's Avatar
I recalculated mine via a Gryphon programmer, wasn't too far off though, maybe 4-5 kph. I ran my 275/70/18 BFG At's for about 2 months before I got my level kit, I had no issues with rubbing, I just liked the look of a leveled truck.
