Do you have Cooper Zeon LTZ or General Grabber AT2 tires?
I looked at a lot of reviews online and they look like the tire to buy, I just placed an order with Sears. One question I have is what inflation should I keep them at? The factory tires were rated at 44lbs. maximum inflation, and the door sticker says put in 35lbs. The new tires I ordered have an 80lb maximum inflation rating, so am I right to assume that I should put in in the same percentage in the new tires, which would be 64lbs? 35lbs is about 80 percent of 44lbs, and 64lbs. is about 80 percent of 80.
The tires I'm getting have an E rating, so I don't know if max inflation would be cause more wear in the middle. I saw on one of the message forums mentioned putting chalk several places on the tire and driving for a few blocks, and seeing where the chalk wears off.
