Going to the ghetto for some rims next week - base question?
For an 05 F150 with 295/70/17 Nittos I want to replace the stock rims. I know the bolt pattern is 6-135 but before I walk into a shop and get taken like a fool can anyone give me a base range I need to be looking for?
I'm ok with flush tires being tucked in but I would rather them stick out a tad. Is their a offset range I should stay between and anything else I need to make notes about before walking my white **** into these shops?
Most 17" wheels are 8 or 9 inches wide with backspacing 4 1/2 to 5 1/2 inches. A 17x8 with 5 1.2 inches of BS is as close to stock specs as you can get and will only stick out 1/2" more then stock. A 9" wheel with 5 inches of BS will stick out 2 inches more then stock. This is what I have on my truck now. Hope it's not too confusing!
https://www.f150online.com/forums/me...e136511-a.html
You have 17x9 w/5 inches of backspace with a bolt pattern of 6-135, correct?
Also why did PorkCereal say +20-25? That seems alot more than 5 inches of BS.
So in this picture:
So in this picture:
