Need advice...315/70/17 on my truck?
Old 07-24-2010 | 08:08 PM
ballinfarmboy92's Avatar
I have a 2000 f150 with off road package. I need new tires before i get inspected by the end of july so i want to go as big as possible. Im thinking the goodyear dura tracs but dont know what size. I have no lift except for a spring helper in the rear which adds an inch and the axle blocks that came with it. In the front i will crank the tbars and trim valence. So how big can i go? I think i can do 305/70s but was wondering what yall think about the 315/70s. What would be better in the long run for my truck components if it matters? Also what size wheel should i go with and what back spacing? I found a good deal on 17x9 Also if i went with the 35s would i have to make any additional mods if i want to keep it driving simalar to the way it is now? Sorry for all the questions guys but im gettin down to the wire and would love some help
Old 07-24-2010 | 08:13 PM
4wd150's Avatar
i am running 305/65/17 now with the tbars cranked a bit, i personally think its a good size for a stock height truck. i hear of few people running 315/70/17 on the stock or close to stock wheels with torsion bars maxed out, valence trimmed, and they rub at full lock. let wandell chime in here he knows his tire/wheel stuff well.
Old 07-24-2010 | 11:38 PM
wandell's Avatar
You can fit a 315/70-17 (35x12.50) if you use your OEM 17x7.5 inch wheels. If you go with a 9 inch wide wheel, stick with a 305/65-17 (33x12.50).
Quick Reply: Need advice...315/70/17 on my truck?
