Need the hard brake line for 2003 that goes from ABS to right front brake. Ford says discontinued. Any ideas where I can get one? Local junk yards were cut when folks get ABS system.
Your best bet would be to go to a parts store like napa and get a straight line, then bend/cut it to fit. But, to cut it you need to have the proper flaring kit.
Crown performance. You can get different colors the coating that goes around the stainless steel brake lines. They already have them pre made for F150s just call them to confirm though. I think they have like 16 different colors to choose from too.
Thanks - will call. NAPA did not carry. The hard line I an talking about has about 4 nends just leaving the ABS, then it goes under the engine and up the right side around the control arm and then to the brake.
OK this line is the one that goes under the engine. It has way to many bends. And evry time I do a double flare on 3/16 tube it takes me about 4 attempts to get one good one. Obtw classic performance only makes wheel lines. Going to try Classic Tube.
