Upgrading a 2wd with a V6
Hey guys, I'm a teenager and wanting to get some help on where to purchase upgrades and what would look good. I think I want 285/75/16 tires and gonna purchase upgraded rims in the same size, should I go with 18"? Also, I'm just going to purchase a 3 inch front level kit to save myself money/ How would that look? thanks in advance
![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
Just kidding. Theres alot of 2wd trucks(mine also) to use as inspiration. I might not be that much help, but never know. How much are you looking to spend is what we should discuss.
Oh no way man! 2wds are super easy to lift! Plus when you regear, you only have one axle to worry about. They look just as good as 4wds too, but obviously the function isnt there. There's alot of old body style lifted 2wds around here if you want help with that. Or are you looking for performance mods? Theres tons of stuff you can do if you have a stock truck now.
Well you have a few options. You can choose to spend most of the money on lift and tires, and less on wheels. OR you can spend more on wheels and less on lift and tires. You can find a good lift and some nice tires, but have to run stock wheels(nothing wrong with that) for $1500. My proposition to you would be...
1.) PA body lift off of amazon.com for $174 bucks
2.) daystar 1.5 spacer with camber bolts and a alignment $100 or so
3.) nice wheels and used tires
OR
nice tires, stock wheels.
Another option would be buying a 3.5" spindle lift, but thats going to run you $400ish just for the spindles. Fortunately, all you would need is the spindles in the front but you would need lift blocks and shocks out back.
You could run a 3.5" spindle lift as well as a body lift and put some used 35s on it. You would have to trim the bumper valance just a little bit, but that would be a massive difference in the appearance in your truck.
OR
Well, its hard to say. It all depends on how high you want it lifted, what size tires you want to run and what you want it to look like.
When I was fresh out of high school, and lifted my truck the first time around. I went with a body lift first, and I still believe now that was a great $175 well spent. I do, however, have an automatic trans and I am not sure if you do. Body lifts have to have a extension welded in for a standard transmission.
Lift spindles are always a good idea when lifting a 2wd, but if you aren't wanting to replace your new shocks then I wouldn't mess with an actual suspension lift. I would run a body lift with a 1.5" coil spacer and then buy some really nice tires. Here is a picture of my truck back when all it has was a body lift and 16x10 wheels with 285/75/16 hercules trail diggers on it. I spent a little over $1800 on this set-up but that was with brand new tires and wheels.
![](http://i33.tinypic.com/2qsq529.jpg)
![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
You can do like Mr jake over here has and be a craigslist *****, and you can find all kinda stuff. If you can find some nice wheels and tires for less than a grand then you should be set with whatever lift set-up you want.
