Will this fit?
The problem with the OEM 20's is they have 6.5 inches of backspacing. Some members have found that some 12.50 inch wide tires will touch the uppercontrol arm/ball joint when you bolt the wheels on. This is usually a problem with mud tires (like the Toyo MT's) with aggressive sidewalls. Some members have solved this problem with thin (1/8 or 1/4 inch) wheel spacer. However, wheel spacers can cause vibration issues.
