Biggest tire on 20s with leveling kit
Hey guys, its that time again to buy new tires for my truck ( 2005 f150 supercrew fx4) . Im currenly riding on the stock tires and rims. I figured if im going to spend the money, I might as well spend a little extra and get what i want.
The question is what is the biggest tire i can fit on a set of Mamba M1 20s with little to no rubbing?
The specs are:
Offset: +30mm
Backspacing: 6.18"
Bolt Pattern: 6-135
Rec. Tire Size:275/55-20
Weight: 39.0lbs.
Also, I want my truck to sit as level as possible so i was thinking about a 2.5" leveling kit. I would rather have the front a little lower than the back, than have the front sit higher than the back. Is a 2.5" right for me?
Sorry for all the questions, i have been searching and banging my head on my computer desk for a while now, these darn tire sizes are confusing and driving me nuts. Thanks in advance guys.
Nic
The specs are:
Offset: +30mm
Backspacing: 6.18"
Bolt Pattern: 6-135
Weight: 39.0lbs.
Nic
I ran 285/65/20s with my old rims that were +35 offset, that size should fit your just fine too. Or some 35x12x20 should fit fine. I'm still running the 285/65/20 tires on my new wheels.
I'd go with a 2.0" leveling kit, it'll help keep you from getting the nose up look you don't want, and the angles won't be as extreme up front.
- NCSU
- NCSU
Hey guys, thanks for the quick replies. Do you really think i could run 35s on those rims with no rubbing? That is a butt-load of rubber. I was hoping to be able to put 35/12/20 on those rims initially, just wasnt sure how much if any rubbing i would have to deal with.
NCSU nice truck man, i like the no running board look, might have to do the same with mine. Why did you decide to go with 285/65/20 instead of 35/12/20?
Whats the difference between the two anyway?
Nic
Nic
Nic
Nic
http://www.youtube.com/watch?v=BG_0jJj9HS0
I went with the 285/65/20 because I wanted to get the BFG T/A KOs and they don't come in a 35" that fits a 20" rim.
The 285 is a little skinnier than the 35x12.
- NCSU
