Wheel and Tire setup
I have a 2006 f150 4 x 4. I am looking to put a set of moto metal M0957 wheels- 17'' x 9'' with a -12mm offset. And go with a 285/75/17 tire. I am going to put a 2.5'' leveling kit on. Does anyone know if I will have any clearance prblems or not? Is any one else running this setup or simular. I will be mostly on the highway. Thanks
That should clear without a problem. You will have to possibly do some trimming down on the front lower portion of your plastic under the fender but not much at all. Just the tip to give you that little extra clearance. Its going to be tight for sure, but will be a good look and work well. Best thing I can say to do is to install the leveling kit and then test fit the drivers side front. This seems to be a tighter fit then the passenger side. Turn the wheels lock to lock and see if it rubs anywhere. You might see a little rubbing lock to lock on the frame, but that is minor.
Thank you
Derrick
Thank you
Derrick
