anyone buy these Rotors and brakes
i need some new front Rotors so i was looking on e-bay and found theses, they seem like a really good price.. just wonder if anyone else bought any.. or any input on these...
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
That is not a rotor that I am familiar with. I would say, judging from the cost of the rotors that they are a lower quality rotor. I would also be a little nervous that they are a drilled rotor. Drilled rotors have a great look to them but this is also a weak spot on the rotor. Depending on your driving style, if you do a lot of heavy braking or live in a very hilly area this will produce a lot more heat and normally what you find is that the rotor will crack between the drilled holes and then from there warp. I always recommend sticking with a slotted rotor and staying clear from the drilled rotors. I have been running the Power Slot rotors and have had great luck with them under medium to heavy braking conditions.
http://www.tirerack.com/a.jsp?a=BZ1&...4&autoModClar=
I hope this helps.
Thank you,
Derrick
I hope this helps.
Thank you,
Derrick
This should help out: https://www.f150online.com/forums/20...try-these.html
